EZ-WifiBroadcast DIY HD видео своими руками
Тесты встроенного вайфая или внешнего?
Почитал комментарии к видео.
Поднялся хотспот, наботает и на 5G и на 2,4. Но только с образом Open.HD. Это значит, что моя 3B+ в порядке.На EZ и на Лёлика образе устройства не видят точки доступа.
Hello Mates,
This is Justin from OpenHD.
I have been trying to follow along and I just wanted to share a couple quick points, I realize there is sometimes a language barrier here.
So, I just have some notes/comments.
Since so many people are active on this forum, it pains me to see people buying the older RPI 2b+ & 3b…
We have extensively tested the Russian 1.6 image and OpemHD of course on 3b+ and that works fine if you prefer to use. It also has a lot more CPU headroom for future enhancements. 😃
USB Camera stuff… Instructions on the wiki.
Compatible cards for OpemHD
--------2.4GHZ----------
2.4Ghz ATHEROS AR9271 is always the most sensible choice.
-Alfa AWUS036NHA
-Alfa Tube UNA (New) ar9271
-Ubiquiti ext
-Blue ar9271aliexpress * Seems to work for Khomyakk but I have had 6 or 7 fail myself even with a cooling fan. **Khomyakk, should you be able to share the link to the exact blue ones you buy?
-The small cheap green AR9271 aliexpress cards (60-90mw) absolute perfect little card to combine with a 2w or 4w amplifier to obtain a CLEAN 800-1000mw output.
------5.8Ghz Only------
*2.4g with the rtl8812au driver has always been broken on all Wi-Fi broadcast and open HD projects. This is known to aircrack but still hasn’t been solved unfortunately
Sorry, what I typed was actually twice as long as above. Hmmm. Must have lost it…
Well… I dont have time to retype that half so, if you have any questions on the open HD stuff feel free to ask me.
Cheers!������
Хэллоу, Justin! Спасибо) В будущем точно появятся вопросы, обязательно спрошу у тебя! 😃
Всё, теперь хотспот заработал на всех извстных образах. Видимо, надо было просто перезалить. Правда, вывести видео на смартфон (ну и в мои андроидные очки) пока не удалось. Попробовал развести частоты бродкаста и wi-fi - не помогло. В вики написано, что “при использовании внутренней карты Wi-Fi невозможно использовать полосу 2,4 Гбит”. Наверно в этом всё дело. Кстати, на трансляции по HDMI видно, как при подкллючении к хотспоту на том же диапазоне (2,4гГц), сразу бьётся много пакетов, картинка сыпется. Так что, даже если и заработает вариант 2,4 + 2,4 , то использовать его - точно плохая идея. Телеметрию пока в смартфон не заводил, да и на экран ещё не вывел. Не с того начал. Просто очень хотелось, чтобы заработал вайфай.
На ютубе нашел тесты В и В+. Именно по вайфай скорость передачи В+ отстает на 40% от В. В остальном опережает немного.
Вроде для данного проекта значения скоростей внутреннего вайфая не очень нужны. Все равно используются внешние адаптеры.
для хотспота используется внутренний
Скажите, кто какой пластик PLA или ABS использует для изготовления корпусов под Pi Zero при 3D печати. Спасибо.
Не специалист, но вроде как пла боится ультрафиолета.
Оффтоп конечно, но отвечу.
PLA боится высоких температур, скромных 50-55 градусов будет достаточно для размягчения. Детальки из чёрного ПЛА летом на ярком солнце могут поплыть. Но сам пластик прочный и долговечный.
ABS в плане термостойкости гораздо лучше, но он крайне токсичный во время печати. Если принтер стоит в жилом помещении, с АБСом связываться не стоит.
PETG (он же PET-G) - по термостойкости близок к АБС, по прочности примерно как ПЛА, даже чуть лучше. Не токсичен, имеет меньшую чем у АБС усадку, поэтому легко печатается.
Nylon, PC, HIPS и прочие - сложны в печати и дороги.
Так что или ABS, или PETG. Корпус из PLA скорее всего поведёт от нагрева малины.
Ну и после солнышка ПЛА начинает распадаться, поэтому для внешних корпусов он мало подходит.
Печатаю PETG. Прозрачным, чтоб лампочки было видно. Ну или волшебный дым, в случае чего…)
ABS и PLA одинаково плохо переносят УФ, особенно жесткий.
PLA становится хрупким, ABS тоже теряет прочность и в добавок мерзко желтеет.
У PETG в этом плане дела заметно лучше, ПЭТ под “естественным” солнечным УФ десятки лет разлагаться будет.
Всем привет . в этой теме пока только читал и вот что то начал делать. Прилагаю видео что бы много не писать
Hi there,
It says that the video is private, you might need to go in and change it to public or unlisted
печатаю АБСом, еще ни одна модель не дожила до таких состояний. аппараты быстрее приходят в негодность
Судя по тому, что интерес к печати оживился в этой теме, предположу, что все печатают/печатали корпуса антена-тракеру? 😃😃
Это само собой.
Речь шла скорее о тех детальках, которые постоянно находятся на улице под воздействием прямых солнечных лучей и других внешних факторов.
Хотя… есть у меня ваза из белого АБСа,которая за год лежания на балконе заметно пожелтела.
Есть такое.
Рисовал / печатал корпус и механику для U360GTS, правда под аналоговый линк 5.8 -> 5.8.
Трекер понравился. Когда дойдут руки до дальнобойного малинового линка, сделаю еще один такой же.
Единственный минус - вики только частично переведена на инглиш, многие страницы доступны только на испанском.
Кстати о трекерах. До U360GTS собирал трекер от zs6buj, не впечатлил.
ПИДа нет, сервы работают в жестком режиме, отсутствие компаса снижает точность позиционирования.
Решил упомянуть его здесь, т.к. zs6buj делал трекер именно для Ez-WBC и у многих здесь он на слуху.
Я напечатал из дешевого пластика SBS, он же Watson. Тот самый синий, из которого мои корпуса. А так вообще, мне нравится PETG, на мой взгляд, самый прочный и с хорошей адгезией слоёв.
У меня пока просто коробочки) Но всё впереди 😃
второй год летаю на коптере рама которого распечатана из PLA чёрного, летом с ней ничего не случилось ни от нагрева ни от солнца, коптер не маленький на 15 пропах и 1.7кило весом
Подождите два года, там посмотрим. 😃
Как там хд линк?
В ветке по телеграмм просто заебади, кто как печатает. Две сотни сообщений.
И ещё две сотни, как они батарпйки цепляют
Сейчас ещё одна сотня, как он разъём подключает
Что пиикольно, все летают и ни одного видео
Лучше скажите у кого какие версии плат нормально работают а то хз что брать. Raspberry Pi 3 Модель, Raspberry Pi Zero W
В вики заходим и читаем. Там написано.
