TBS Discovery - квадрики для FPV
Раздумываю над устройством аварийного поиска, кто что ставит на дискавери? Если Кто использует слоновий маяк , поделитесь опытом, как закрепить это нечто с неаккуратной антенной, и батарей наружу, чтобы это нечто выглядело не только красиво, но и не рассыпалось в полете.?
Инструкция по настрйокам подвеса (на английском)
PROFILE 1
- Remove props.
- Plug in the battery
- Plug in the USB cable and launch the GUI
- Set Motor Power values to 0 - then WRITE (this will keep it from spazzing out while you calibrate)
- Make sure the Pro is on a level surface, then use something to make the gimbal level (camera facing forward) - I used chopsticks
- With the camera facing forward, press the Calib ACC button - watch the LED on the top plate. It will flash for a few seconds then go solid. (flashing = writing)
- Tilt the camera straight down, then press the Calib ACC button - Blue light flashing… Once solid, move on.
- Tilt the camera straight up, then press the Calib ACC button - Blue light flashing… Once solid, move on.
- Tilt the camera straight backwards, camera facing the rear, then press Calib ACC. - Blue light flashing… Once solid, move on.
- Press Write
- Set the camera straight forward, triple check that everything is perfectly level and still, then press Calib Gyro - then Write.
- Change the motor power values back to 175 and 135, then press Write again.
Now I’m not sure if these next steps are completely necessary, but this is what I did.
PROFILE 2
12. Now select Profile 2 from the drop down. - press Write
*The gimbal should be squealing now, and profile 2 should be still shown at the top
13. Set the Motor Power to 0 on both - press Write.
14.Click on the RC Settings Tab, and set ROLL to “no input” - Press Write.
15. Back on the Basic tab, Just for fun, while listening to the crazy noise, go through the entire calibration process as stated above.
16. Set Motor Power values back to 175 and 135. - Press write
17. Select Profile 1 and press write.
That should be it. But also be sure to COMPLETELY check the range of motion on your gimbal. Even the slightest bit of resistance can cause the shakes.
я лично присматриваюсь к этому:
www.ebay.com/itm/…/270878226109
Большое спасибо, вроде с Гошей NFLS справились, но очень сильно вибрирурет теперь камера и люфтит левый двигатель подвеса. Это из-за этих болтов безшапочных?
болтов безшапочных?
Шпильки)
Из-за них и вибрирует камера
Шпильки)
Посоветуйте, как их теперь выкрутить - капнуть клеем на тонкий шестригранник? Хотя миллиметрового шестригранника у меня нет или попытаться выкрутить их с помощью самореза?
Миш, у меня была мысль выкрутить второй (первый удалось сразу), капнув клея капельку. Но, есть риск приклеить намертво шпильку к резбе. Поэтому я его оставил в резьбе без выкручивания.
И вопрос- если у тебя нет такого шестигранника, как ты его вкурчивал тогда?
Андрей, удивитесь - я вкручивал руками!
Потом перешел на T-motor
Какая модель?
Какая модель?
T-motor 2216
сначала снимите ось двигателя из рамки (не знаю как она правильно называется) легкими постукиваниями, потом их выкрутить можно даже испорченым шестигранником.
Винты для оси подвеса (нержавейка):
www.rcscrewz.com/product_info.php/p/…/279
только доставка дороговата…
А что если высверлить эту шпильку, которая ближе всего к боковому мотору подвеса?
www.rcscrewz.com/product_info...roducts_id/279
Это не те винты, Андрей, они шире, там винт миллиметр максимум в диаметре.
Опишите подробнее процесс, пожалуйста!
Это не те винты,
Там резьба М2 😃
Подобный винт стоит у меня на Про
Кому будет интересно как победить люфт подвеса не вынимая шпилек, опишу ход своих действий и подробную инструкцию к действию:
- Нужно отчаяться, расстроиться, вынести мозг всей семье и только после этого успокоиться.
- Объехать все ювелирные мастерские, часовые и ремонты телефонов в округе, заходя к ним в отделы с грустными глазами и призывая их к помощи.
- Расстроиться, что не один часовых, ювелирных дел мастер не откликнулся на просьбу помощи и поехать задумчивым дальше по своим делам.
- Настроиться на самые категоричные и решительные действия.
- Взять в руки дрель, вставить в нее самое тонкое сверло, вставить в отверстие, где находится шпилька и медленно, не спеша, попытаться сначала вкрутить сверло, а потом попытаться вывкрутить. Опережая процесс, скажу, что выкрутить не удастся. Расстроиться снова.
- Разобрать боковую часть подвеса, к которой прикреплен мотор, понять, что это было сделано напрасно и ничего это не даст.
- О чудо, подвес больше не люфтит.
За счет чего? За счет того, что дрелью мы:
а - либо расширили шпильку внутри отверстия подвеса;
б - либо вкрутили его глубже, тем самым устранив люфт.
Возможные варианты развития событий - либо все будет хорошо и проблем более не возникнет, либо в будущем снова придется думать как бороться с этой занозой!
Точно
А еще можно написать письмо на ТБС и попросить заменить деталь подвеса, мотивировав, что винты плохие и слабый шестигранник не позволил зафиксировать ось мотора. И после вкручивания нет возможности выкрутить обратно, из-за низкого качества металла.
А пока придет замена летать, на чем есть 😃
Ответили:
We apologize for this. May we ask which part of the gimbal was damaged? If you could send us a photo of it.
Also, we do have available screw set but they are in silver. Black ones will be available on the 17th of this month. Would this be okay? Please advise.
Best regards,
Sherell
Customer Service Representative
TBS Avionics Co Ltd.
Сфотай сторону, где не содрано черное покрытие и отправь им.
Напиши, что эту деталь и просишь заменить и винты серебряного цвета тебе подойдут.
Сейчас в личку отпишу на англицком…
кто как подключал rssi от обычных приемников?
у меня футаба 6208, вот думаю если подключу через сопротивление 100ком, все ли нормально работать будет…
никто не пробовал?
Всем доброго времени суток.
вопрос к обладателям сего квадрокоптера на apm 2.*. Покажите пожалуйста, на фото как у Вас расположено: полетный контроллер (у меня внутрь влезает только без коробочки, иначе контакты упираются в верхнюю плату), osd, датчик тока, приемник, gps (возможно кто-то и компас выносил),видео передатчик. Планирую использовать моторы 700 кв, пропеллеры 11*4.7, карбоновые удлинители лучей. АКБ зиппи компакт 3s 5000. Скорее всего акб будет на верхней плате, т.к в “хвосту” будет перевешивать.
Спасибо!
Привет всем. Мужики помогите плиз определиться с местом расположения на tbs контроллера apm 2.5.2 ?
Честно прочитал пол темы, но так толком ответа и не нашёл. На данный момент apm разместил в точке крепления, обозначенной монтажными отверстиями нижней пластины, но на верхней пластине. Летает неплохо но в режиме альтхолд тянет вниз при полёте вперёд и наоборот. Батарею размещаю ближе к центру так, чтобы центр гравитации был в положенном месте (15мм от точки тяги).
Не понял, ты что, процессор разместил вверх ногами??
Нет конечно. Просто На верхней пластине, но в позиции ближе к передним лучам (там где на нижней пластине квадрат крепления).
Собственно основной вопрос - где правильно размещать и какие подстройки делать ?
Вот еще вариант крепления тарота
А что это за рама, явно не дискавери.
