3DR IRIS+ - встречаем!
Covax
store.3drobotics.com/products/iris/
Ready to Fly
Inside the IRIS+ box is everything you need to fly. Simply attach the props, charge the battery, and you’re ready to fly manually with the included remote control or autonomously with a Mac, PC, Linux or Android device.
Flight Protection
The IRIS+ can land itself automatically, or return to a home point if it travels out of range or runs low on battery.
Follow Me
3DR’s 3PV™ (Third Person View) Follow Me technology turns your IRIS+ into a hands-free aerial camera crew that puts you in the middle of your own adventure. The IRIS+ can easily follow and film you while carrying any GPS enabled Android device. This advanced technology simultaneously controls the gimbal to keep the camera centered on you, capturing sweeping cinematic video from a perspective unlike any other.
Auto Mission Planning
With free DroidPlanner 2 software, IRIS+ users can plan flights by simply drawing a flight path on any Android tablet or phone, which allows for hands-free flight control. Now your drone will go where you tell it to go, and it can even keep your GoPro pointed at the same location via a Region of Interest waypoint throughout the entire flight. This enables fun autonomous journeys, and automatically stabilized video capture that would be otherwise impossible.
Includes
• Ready-to-Fly IRIS+
• Transmitter
• 3DR telemetry radio
• Micro USB cable
• Android OTG cable
• Set of tall legs for IRIS+
• 5100mAh 3S battery
• LiPo charger
• Manual and flight checklist
Performance
Maximum payload: 400 g (.8 lb) payload capacity
Flight time: 16-22 minutes depending on payload
Height: 100 mm
Motor-to-motor dimension: 550 mm
Weight with battery: 1282 g (100% без подвеса)
Electronics
Autopilot hardware: Next generation 32-bit Pixhawk with Cortex M4 processor
GPS: uBlox GPS with integrated magnetometer
Controller: Any PPM compatible RC unit, Preconfigured FlySky FS-TH9x RC
Telemetry: 3DR Radio 915mHz or 433mHz
Components
Propellers: (2) 9.5 x 4.5 tiger motor multi-rotor self-tightening counterclockwise rotation, (2) 9.5 x 4.5 tiger motor multi-rotor self-tightening clockwise rotation
Motors: 920 kV
Mounts: Integrated GoPro camera mount with vibration dampener
Optional: Tarot brushless gimbal with custom IRIS+ mounting kit
Battery: 5100 mAh 3S
Purchase
The IRIS+ drone by 3D Robotics is all you need to start seeing and sharing your world from above. Starting at $750, with optional gimbal for $219.
Covax
всегда можно через посредника заказать
pilot258
Чем бы не был, за такую сумму, лучше купить все в сборе. И на деле разобраться.
k1ndcat
ну собственно чуть позже “джедаи” (я так понял это их же суббренд) впихнут туда аккум. побольше, как было с фантомом 2 - время будет 30 мин 😃
Интересна сама технология, не нужно покупать, как на примере Фантома 2, чтобы летать по координатам еще и айпад гроунд стейшн, по стоимости соизмеримой с самим квадриком, тут уже “всё включено” 😃
mitmit
после истории с ДЖИдаями колина взяли пиарить 3др;) интересно, хороший знак или плохой?
14 days later
Вадимм
Covax:
Будут проблемы при использование 915mHz ?
fidller
а кто то заказал? в Россию я так понял не шлют
Вадимм
fidller:
а кто то заказал?
Я пытаюсь, но не у них, но там Radio 915mHz, вот и интересуюсь.
fidller
та радио можно поменять. копейки стоит
Вадимм
Почитал форумы, что то не очень гладко с временем полета, и еще жалуются что когда акб на исходе то газ приходится держать 80% а то и все 100.
Mikhail_Yunin
mitmit:
взяли пиарить 3др интересно, хороший знак или плохой?
Думаю-это хороший знак, ибо платформа ардуино - позволяет более гибко оптимизировать полетный контроллер.
И там есть что пиарить в отличии от закрытых систем - типа подключи этот коннектор в это гнездо.( и прикупи кучу барахла)
Или вообще - по типу не кидайте в пианиста - он летает, как умеет.( созданных “мастерами”- для фиг знает кого)
Однако !
присмотритесь к реальным - не рекламным видео IRIS может не все так радужно?
Sir_Alex
Mikhail_Yunin:
Там от Ардуино ничего не осталось 😉
Drinker
У меня Ирис есть, девелопер едишн, с пиксхавком еще без мпу. А под прошлый новый год 3др прислали бесплатно второй пиксхавк уже окончательной версии. Приятно, че. А в ирисе не менял ни пиксхавк, ни его настройки. Летает отлично. Правда почему-то отсечка (пищать начинает) уже через 4 минуты на любой батарее. Думаю где-то нужно настройки датчика тока-напряжения подправить.
Вот он
Да, и во еще - пластик очччень крепкий. Я думал хрупкий, а нет.
kestrel
Скажите это реально производитель так укладывает антенны приемника в ИРИСе или это чья-то доморощенная халтура (самостоятельная установка) ?
Судя по данному снимку еще и GPS модуль без экранирования устанавливается.
4 months later
Лятун
ДОброго здравия! Прикупил его, на днях жду. Кому интересно потом расскажу.
