Feima Robotics J.ME WIFI FPV With UHD 4K Camera
Новый компактный дрон от друзей китайцев:
Характеристики:
General Brand: Feima
Model: J.ME
Quantity:1 Piece
Color: White
Quadcopter
Weight (Battery included): 550g
Body size (Propellers excluded): 169mm×169mm×70mm
Maximum altitude: 3500m
Lifetime: 23 mins
Working environment temrepature: -10° to 40°C
Max acceptable wind level: 4 level (5.5m/s~8.3m/s)
Outdoor positioning system: GPS/GLONASS/Beidou 3-mode satellite positioning
Indoor positioning system: Optical flow +Ultrasonic
Controlled distance/Image transmission: 200m/100m(Open and no interference)
Maximum ascend speed: 1m/s
Maximum descent speed: 1m/s
Maximum horizontal flight speed: 8m/s
GPS hover accuracy
Horizontal position accuracy ±1m
Vertical position accuracy ±0.5m
Optical flow ultrasonic hover accuracy
Horizontal position accuracy: ±0.3m
Vertical position accuracy: ±0.1m
Gimbal
Pitch: -15°~90°(Downward)
Roll: ±25°
Front view obstacle perception system
Obstacle perception range: 0.06~2m
Operation environment: Indoor
Visual positioning system Speed measure range: Flight speed <4m/s(Height 2m,Plenty light >15 Lux)
Height measure range: 0.35~3m
Accurate hover range: 0.35~3m
Operation environment: Rich texture on the surface,adequate light(>15lux,indoor normal exposure environment in fluorescent light)
Camera
Image sensor: 1/3.06 inch CMOS;effective pixel :13 MP
Lens: FOV 76°;28mm(35mm Format equivalent),Focus is endless;f/2.0
ISO Range: 100,200,400,800,1600,3200,6400,Exposure mode is valid for manual exposure,default :100
Electronic shutter speed: 1s~1/8000s
Pic max resolution: 4096*3072
Picture shooting mode: Single shoot:support capture when taking video,default : single
Continuous shooting: 3,5,7,Default :5
Timed shooting: 5s,10s,15s,20s,default :10s
Delay shoot: 5s,10s,15s,20s,default :10s
Video resolution
4K:3840x2160, 20fps
1080p:1920x1080, 30fps,Default :1080p 30fps
720p:1280x720, 30fps
Delay :5s,10s,15s,20s,default :10s
Picture format: JPG
Video format: MP4,3GP
Memery card: 32GB
Working temperature: -10° to 40°C
Charger
Voltage: 16.8V
Power: 57W
Intelligent Flight Battery(FM3000)
Rated capacity: 3000mAh
Rated power: 43.2Wh
Standard voltage: 14.4V
Battery type: Lipo 4S
Working environment temperature: -10° to 40°C
Limited voltage of charging: 16.8V
APP
Name of App: J.ME Fly
Real-time transmission: 1280×720@30fps
Delay: 150 ms(Depend on real shooting environment and mobile device)
Version for mobile device: Android 4.3 and above ,iOS 9.0 and above
Функции:
One Key Takeoff / Landing
One press automatically taking off or landing, rc quadcopter will take off or go back to the position where it took off.
Waypoints
Set one waypoint ,J.ME will be centered on that point , and hover at the same height
Interactive Flight Control System
Basing on MTK Hello X20 smart chip,independent development.Realizing smart flying precision poistioning and hovering.
4K Camera
Equipped with 4K camera which can shoot 4K/30 fps video and 12MP pictures.
720p HD Real-time Video Transmission
720P HD Live View,catch every exiciting moments.
Gimbal Stabilization
The smallest 2-axis gimbal all over the world, the gimbal is just 35 g(camera included )
Mechanical and electronic double stabilization, green hand can shoot clear image
Use IIGC adaptive control algorithm, PTZ jitter accuracy is up±0.02°
23 Minutes Flight Time
Fly for up to 23 minutes on a single charge. Intelligent battery makes it easy to check ,safe and worry-free.
Follow Me
With Follow Me, the aircraft will automatically follow you and capture your every move from a unique aerial perspective.
Indoor positioning and obstacle avoidance
With advanced Optical Flow module, ultrasound module. Support flight safe and hover indoor without GPS,which let J.ME detect horizontal position and flight height.
One Key to Share
Capture every wonderful moment,one key to share to social web.
Обзор на русском языке пока доступен только в одном варианте dronomania.ru/…/selfi-dron-j-me-ot-feima-robotics.….
НА сегодня можно купить только на geekbuying.com по цене $475.
Присматриваюсь к такому…жаль что нет пульта!
настораживает отсутствие доп пропеллеров…они же не стандартные…
доп пропеллеры есть уже давно в продаже…С зеротеч они тоже не идут в комплекте, как и со многими дронами.
Ждём результатов полётов, оценку управляемости и качество видео!
Всем привет. У нас в Пензе сейчас погода не летная: днем 0 -2, сильный ветер, но вчера удалось пару минут полетать.
Вчера при сильном ветре удалось поднять его на 57 метров (dobby в том же месте с этим же телефоном и без ветра поднимался на 43 метра и терял связь) с помощью не очень сильного телефона в плане wi-fi (iphone se). Выше не стал, пока страшно при таком ветре:)
В инструкции описано, что у данного дрона не слабый передатчик wi-fi — 19 dbi при 2,4 и 16 dbi при 5 мгц.
Время полета пока так же не замерял, iphone при такой погоде просто отрубается через 3 минуты от холода:( Вообще, по сути, пока и написать то нечего.
Так как у ПО предусмотрен режим обучения, то при моем статусе “Новичок” дрон пока отказывается летать в помещении без GPS. Необходимо выполнить несколько заданий, после которых открываются новые функции дрона. Максимальный режим будет доступен только при выполнении всех полетных заданий и налета 300 минут.
И, да–разбирал ради интереса батарею, стоят 4 шт 18650 (шоколадки) в параллее, так что проблем с заменой батарей вообще нет.
Видео в формате 1080:
- где днем-- это сильный ветер, к тому же плохо его откалибровал, летал кругами.
- В темноте – при 0 и небольшом дожде.
rutube.ru/…/26e37c0eaac0216b36f073046b1f36ee/
rutube.ru/…/5d7492127ca5d147adea070d8eb77465/
есть и плюсы и минусы без пульта…заказал себе еще wi-fi extender для увеличения зоны приема-передачи, на дроне стоит мошний передатчик на 19 dbi
Картинка хорошая, это, конечно не Добби, но и не Мавик. Ждём продолжения! Для управления могу посоветовать Nvidia Shield Portable - отличная штуковина и экран, и джойстики в одном флаконе.
не дешевый джой
Вообщем сегодня в обед было солнечно у нас, 0 градусов. Чуток удалось полетать.
Все функции дрона пока не разблокированы, налетал только до “студент”. До следующего уровня необходимо налетать минимум 200 минут, до полной свободы-300 минут. Полет по точкам и др. функции --пока закрыты.
Сегодня с помощью iphone (не славитстя он модулем wi-fi) поднял дрон на 110 метров, впечатлен, передача видео не прекратилась, были небольшие задержки только.
Что касается функции “Возврат домой”- работает отлично. С одного заряда, вернее с 83% процентов пролетал около 20 минут.
Очень понравилось, что заряжается с 5% до 100% всег оза 1 час.
Если сравнивать с добби, то небо и земля!!! Что по качеству самого изделия, качеству видео, функциям и автономности. Да, он больше немного, но винты снимаются за 15 секунд и все аккуратно упаковывается в небольшую наплечную сумку.
Ниже чуток видео, качестов 1080, по крайней мере так загрузил на ютуб.
сегодня выложили из за бугра отличный обзор blackcatgadgets.com/jme-4k-drone-unboxing-review/
группа по данному дрону в www.facebook.com/groups/2412...?ref=bookmarks
кстати, кто то тут говорил, что плохо нет пульта: команда Feima Robotics в настоящее время трудится над созданием пульта для него:)
К любому дрону, который управляется по Wi-fi, есть отличный готовый пульт - Nvidia Shield Portable. Проверено - очень удобно!
Ниже чуток видео
Может ND фильтр попробовать ? Желе ощутимое.
Еще немного видео
Да, желе сильное. Может пропы поменять? Прям обидно.
Желе может быть от того что кот чуток погрыз винты?. Заказал винты новые, жду.
Всё может быть,хотя в китайских видео тоже есть желе. ((
Посмотрите видео в группе в Фейсбуке, там американский тестер выкладывал
О китайцы наконец решили использовать стандантные элементы питания ?
а не знамо какие банки ? и правильно у 18650 с качеством а главное доступностью и ценой все просто супер )
А какая конфигурация акков ? 4S1P ? и как я понял акк не быстросменны сменный ?
т.е. поменять быстро нельзя и он зашит в корпусе?
маркировку не смотрел, так как они между собой по полюсам спаены пластинами (марикровка внутри акков была), а весь блок из 4 ааков вынимать не стал.
Но заменить не составит труда: вытащить весь блок из 4 акков, спаять по аналогии такой же из 4 акков, (напрмер на 3400 уже есть, с защитой) и припаять штекер.
В поле менять тоже особого труда нет, выкрутить 6 винтов и все. Лучше чем брать новый родной акк за 5300. 😃
, с защитой
только без защиты ставь акки.
Плата может как я понимаю по току отрубить и все(.
Да и больше они чуть чуть по габаритам
Кто летает? Уже 380 стоит. Интересный аппарат. Запчасти какие продаются?
я изначально и летаю. Запчасти есть в продаже: сумка, батарея, винты-оригиналы. Так же уже умельцы ставят двухлопастные 6045 винты:)
Интересно, а где вы цену нашли за 380?
Ксатит, через 1,5 примерно месяца, Feima выпускает для него контроллер.
