Правильно ли подобрана комплектация 450-ки
Такой комплект 450-ки чтобы не дозаказывать мелочевку -норм? Хоббикинг.
1 OK F009 - Part # F009 $0.47 9
1 OK HK7x-M2 - HK-7X 2.4Ghz 7ch w/ 5 Model Memory TX & … $59.95 979
1 OK F002U - Main Blade Holder Set Upgrade (HK450) $5.29 25
1 OK TR_P40A - TURNIGY Plush 40amp Speed Controller $23.10 79
2 OK F010 - Part # F010 Flybar Paddle Set $1.94 50
1 OK S618 - Curved ball link pliers 5mm $4.43 129
1 OK V2-229 - HK450V2 Metal Landing Skid $4.26 29
2 OK F002 - Part # F002 Main Blade Holder Set $3.98 46
1 OK V2-117 - HK450V2 Metal Tail Boom Holder $5.49 29
2 OK HK450GT - HK-450GT CCPM 3D Full Alloy Helicopter K… $93.98 1994
2 OK V2-147 - HK450V2 Main Shaft $4.10 130
6 OK GF335 - 450 class Fiberglass Main Blade 335mm $20.58 414
1 OK S609A - Turnigy R/C Helicopter Pitch Gauge $1.49 43
2 OK F022 - Part # F022 Landing Skid $3.38 80
4 OK F047 - Part # F047 Canopy $2.56 280
1 OK TR22235-3500 - Turnigy 450/500 H2223 Brushless outrunne… $12.04 109
1 OK F050 - Part # F050 $1.19 9
1 OK F028U - Tail Unit Upgrade (HK450) $5.99 27
1 OK TR22234-4400 - Turnigy 450/500 H2223 Brushless outrunne… $12.04 109
4 OK MG90S - Turnigy MG90S Metal Gear Servo 1.8kg / 1… $19.96 148
1 OK HKS9257 - HKS-9257 High Speed Servo 4.5kg/ 25g/ 0… $10.92 43
5 OK V2-132 - HK450V2 Tail Boom $3.75 445
4 OK Z22003S20C - ZIPPY Flightmax 2200mAh 3S1P 20C $35.96 924
3 OK V2-145 - HK-450 Metal Tail Rotor Shaft upgrade ve… $3.96 57
1 OK GA-250 - HobbyKing GA-250 MINI-MEMS Gyro $9.99 45
4 OK F020 - Part # F020 $10.24 144
3 OK F028 - Part # F028 Tail Unit $5.07 63
3 OK V2-140 - HK450V2 Main Gear Set $9.06 159
2 OK V2-133 - HK450V2 Tail Support Rod $2.68 38
1 OK 601Ax5 - Male XT60 connectors (5pcs/bag) GENUINE $2.44 29
2 OK CFT95 - Carbon Fiber Tail Blade 95mm $6.44 42
2 OK F035 - Part # F035 Frame Hardware Pack $2.58 42
1 OK S632 - Turnigy Hex Driver set 1.5~ 3.0 $3.99 139
1 OK GWSPARKHPXF/BB/F - GWS Park HPX Servo 19g/.05sec/3.6kg (Fut… $12.35 35
1 OK BOX-439g - Extra Length Cardboard Box and Packing 4… $0.00 439
1 OK F001U - Main Rotor Holder set Upgrade (HK450) $3.49 23
Два движка т.к. не могу выбрать что лучше. Две сервы на хвост- выберу при полетах. Можно ли такую емкость аккумов отправлять в однои посылке- слышал что нет. Не беру то что в бакодере.
Вы правда ожидаете, что кто-то заморочится и весь Ваш список поищет на ХК и оценит? Сделали бы хотя бы ссылки для удобства.
Извините за резкость.
Это движок - клон Скорпиона-шестерки. Ранее, чем через год он вам не понадобится. Поставьте на полочку и пусть стоит 😉 в остальном (кратко просмотрев) вроде все нормально.
Честь Вам и хвала, Александр, за терпение и интерес. И знание ассортимента ХК. 😃
смысл в этих железках??? погнулись - и в мусор.
хватит месяца на три, лучше замените на Инолаб HGD261HB
Аккумуляторы лучше отправить отдельной посылкой.
Ссылки сделать хотел но т.к. не большои спец в комьпьютере минут 15 переносил вручную все названия с саита хоббеи. Расчет был на то, что спецы по названиям разберуться т.к. даже я уже за месяц почти все необходимые комплектующие помню. Кстати так и оказалось!😉
В смысле все и в однои коробке? Читал на форуме, что ограничение 3500мач в один ящик. Думаю придется разбивать на 4 отдельных послания. Или нет? Первыи раз буду брать в Китае.
Чтобы их погнуть это надо хорошо постаратся. Но так же не рекомендую их брать потому как при жёстких посадках, которые у вас будут, они не сглаживают удар. Возмите побольше пластиковых www.hobbyking.com/hobbyking/…/uh_viewItem.asp?idPr…
Так как все таки, сколько аккумуляторов можно слать в однои посылке? Разъясните плиз. Прошу "Братів українців " поделиться знаниями какая нужна пластиковая карта для оплаты (валюта гривна или у.е, Мастер кард или Виза, может какие тонкости) Банковскои карты не имею никакой. В Одессе любят “ЧЁРНЫЙ НАЛ”
Я брал от 500GT, класс,широкие и в наличии есть.Были.
Виза виртуал.
а можно узнать почему берете OK HK7x-M2 - HK-7X 2.4Ghz 7ch w/ 5 Model Memory TX & … $59.95 979, а не турниджи 9x?
Туринжи мод 2 висит в бакодере 2 месяца или более, а так конечно взял бы турингу
дык я в этом случае взял мод 1, придет просто стики переставлю, даж инструкции есть.
Я накидывал в посылку 5 шт 2650 6S. Счет выставлялся к оплате без каких-либо ограничений. Правда, у меня платиновый статус.
Аккумуляторы скомпонуйте в одну посылку, ну не получится - в две, три. Тушку и инструмент для сборки в другую посылку. Запцацки - в третью. Ну и тд. Смотрите стоимость доставки в зависимости от веса - нет линейной закономерности.
При формировании посылки обратите внимание на вес и диапазон, куда он попадает. Переберете десяток граммов, а за доставку посчитают уже по следующему диапазону.
Киньте ссылочку на переделку. Сам над этим думал, но чего-то решил что не получится.
Моё “Варенье из раиских яблочек” весит 7572g и как понимаю однои посылкои вообще никто не повезет. Или я не прав? Самый большои вес SingPost AirParcel 7kg / 7-21Days $103.99, придется разбивать на 2 ящика. Кстати этот перевозчик “Registered” или нет и безопастно ли воспользоваться его услугои , а то для бандеролеи эта характеристика указывается а для посылок нет
Переделывается ровно за 2 минуты перекручиванием 2-х пружин, безо всякой ссылочки 😉 Берите Турнигу в первом моде и даже не думайте, пока еще есть
По поводу банка - ИМХО наиболее удобен Приватбанк с его Приват 24
Хи-хи. Регистред это не перевозчик, это обычная государственная почта, только бандероль зарегистрированная т.е. имеет трек номер. И статус у нее намного выше, обычную бандероль вручают в службе доставки почты, могут вообще в почтовый ящик кинуть, а вот зарегистрированную - только в отделе посылок с паспортом и заполнением квитанций.
Посылку же при хорошем раскладе принесут прямо к вам домой (мне последний раз чего-то не принесли, сцуки, а так обычно - всегда привозят).
Да это я понимаю! Вопрос в том что SingPost AirParcel является ли тем самым перевозчиком у которого моя посылка будет иметь трек номер или нет? Хотя вопрос снят-там (в разделе посылок) все перевозчики без этого “регистреитд”.
Посылка всегда идет “регистред” и плюс к этому - страховая! Только номер трека будет отличаться, у бандеролей в начале идет RB или подобное, у посылок СР
Аккумуляторы в посылке общим весом больше 2500 грамм не поедут, вынесите их в отдельный заказ. По емкости ограничение идет только на какой-то один вид доставки, не помню точно на какой именно… Просто выберете другой вид доставки и все.
а у меня почему то обе посылки с хоббей не трекаются ((
RS909672391CH и CC903578897SG, может быть я что-то не так делаю?
Причем на ХК первая ссылка ведет на swisspost.com а вторая на hongkongpost.com
Вы давно оплатили? Не волнуйтесь, это означает, что они (ХК) послылки ещё до почты не донесли. Они, бывает, их целую неделю несут. То, что номер выдали ещё не означает, что посылка на почте. Тут вообще раздел есть про почту и магазины.
вторую уже 2 недели как оплатил, а первую 5 дней назад. Странно все это)
Свиссовскую посылку надо трекать только через свисспост. До 2-х недель ничего - это нормально.
Дык через свисс и трекаю. Ну вобщем ждать и верить) А почему интересно посылка из гонгконга идет свисспочтой?
Небось, аккумуляторы едут в этой посылке?
А потому, что только свисы не выеживаются с ограничением по емкости батареек.
