Для всех кто купил клон IMAX B6. Перепрограмирование и замена резисторов.
А терминал что пишет???
"i was trying to flash a clone with M0517LBN arm and could’n’t get the cpu into debug mode for SWD flashing.
the solution after 1 day reading PDFs and general searching for how ARM using SWD turned out to be easy but hidden into datasheets…
when the M)517LBN is locked we have to force it into halt state manually just after hardware reset (HW RESET).
the problem:
bin>openocd-0.8.0.exe -f interface/stlink-v2.cfg -f target_M0517_win.tcl
Open On-Chip Debugger 0.8.0 (2014-04-28-08:39)
Licensed under GNU GPL v2
For bug reports, read
openocd.sourceforge.net/doc/doxygen/bugs.html
0
Info : This adapter doesn’t support configurable speed
Info : STLINK v2 JTAG v23 API v2 SWIM v4 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.471484
Error: init mode failed
in procedure ‘transport’
in procedure ‘init’
the solution:
on SWD pinouts force into manual hardware reset by jumper on RST pin (cpu side) to GND (STLink v2 side)
then plug the STLink v2 into USB
use 5V Vcc on STLink v2 side
then run openocd and do not unplug from USB
try 3-4 times by re-running openocd and plug-unplug the RST-on-GND (STLink v2 side)
that’s it
charger - st-link
ICE_DATA <---------> SWDIO
ICE_CLK <---------> SWCLK
ICE_RST <-------->- GND <---------------- plun-unplug to manually reset the cpu
GND - <---------> GND
VCC <---------> 5V Vcc
progs used: openocd to halt and erase chip and CoFlash to prog , using Windows 7"(с)
все так и делаю,подключаю в нормальном режиме потом rst на gnd,потом обратно.при запуске “openocd-0.8.0.exe -f interface/stlink-v2.cfg -f target_M0517_win.tcl”
выдает: C:\STM32\openocd-0.8.0\bin>openocd-0.8.0.exe -f interface/stlink-v2.cfg -f targe
t_M0517_win.tcl
Runtime Error: embedded:startup.tcl:47: Can’t find target_M0517_win.tcl
in procedure ‘script’
at file “embedded:startup.tcl”, line 47
при запуске openocd-0.8.0.exe -f interface/stlink-v2.cfg -f target_M0517_win.cfg:
0
in procedure ‘init’
версия windows играет какую нибудь роль?
нет. Версия системы роли не играет. Играет роль версия openocd но у вас верная.
У вас изначально не проходит процесс ресета и инициализации процессора. Либо подключаете не так, либо не так ресетите.
Ещё до терминала вы должны получить при правильном ресете “кирпич” из зарядника. Он не должен стартовать. Если стартует - значит связи нет.
потом rst на gnd
Чего на что коротите? Не программатор надо сбрасывать, а его и проц. Всё вместе.
"Прекрасное " описание. Что вытаскиваем то? Непонятно.
Попробуйте в правильной конфигурации подключения, ничего не вытаскивая просто при включении STLink закоротить GND и RST. После включения и “пик пик пик” от зарядника перемычку убираете.
Вот за эти танцы и не любят новотон
картинка из под видео с ютуба по прошивке нувотона
и? как резалт?
поставил перемычку при включении на экране зарядника полоса квадратиков,убираю перемычку включается bimax пикает но сброс не сделан.
вообщем результат никак.полного описания прошивки нигде нет кроме ютуба,там каша какая то и нифига не слышно.
а в самом программаторе китайцы могут что нибудь напутать?
Вот это и есть сброс, когда квадратики.
Полное описание есть в файловой сборке cheali. Док файл.
А по результату может и донгл нерабочий или софт криво стоит.
накопал информацию по самим программаторам,у них схемы разные и есть такие что в windows определяются но не работают с передачей данных.в линуксе бы попробовать,только она для меня как темный лес.
Как и программатор.
Как и программатор.
“Не вынесла душа поэта…”(с)))))))))))))))))))))))))))))))))))))))))
Одолело любопытство. А зачем на программаторе пин RST, который не отвечает за перезагрузку во время перепрошивки? К чему все эти манипуляции с передергиванием RST?
Берём китайский программатор за 2.5 бакса и берём китайский зарядник за 17.5 бакса. Итого получаем связку за 20 баксов, которая не работает )))))
На самом деле тут проблема скорее всего не с программатором, а с неправильными таймингами. Ткнувшись осцилографом, отчётливо виден сброс, но он очень короткий и процессор совсем не всегда на него реагирует.
Я когда то тоже мучался с этим программатором, китаезы не правильно напечатали на корпусе маркировку подключения, которая не совпадает с маркировкой на самой плате, я уже об этом писал выше. Попробуйте подключить программатор так
надписи с выводами совпадают,по этой схеме и подключал.
Я зеленым исправил. Как картинке так подключали?
То, что у вас зелёным обозначено, это и есть самая распространённая распиновка ST-LINK V2
Я так понимаю, что по ней и подключали. А то, что красным, то неизвестно какой программатор. На фото не видно.
Да.
Да.
Ну так Ижик так и подключал. Я вообще про него писал.
Возможно Вы меня не понемаете или я Вас, я говорю, что на корпусе самого программатора в обозначении может быть ошибка, так как китайцы суют туда разные платы. По поводу того как подключал Ижик программатор ниже.
подключил к программатору согласно схем на сайте и написанному на самом программаторе.
У меня была такая же ошибка,
пока не разобрал программатор и не сверил с тем что напечатано на корпусе, а на корпусе неправильно. Могу посоветовать разобрать свисток и сверить, тогда станет все понятно.
разбирал,смотрел.схема с распиновкой совпадает
Ну раз пошла такая пьянка и вам именно этот зарядник дорог как память (хотя я бы давно уже его сменил на зарядник на Атмеле), то ткнитесь уж для начала осцилографом по сигналам в момент инициализации.
Всем привет!
Давно пользуюсь этим зарядником. Перепрограммировал его и с зади прикрепил большой алюминиевый радиатор (выкладывал в этой теме фото).
Закупился дешевыми китайскими аккумуляторными батарейками типоразмерами АА и ААА. Скажите - может ли iMax B6 адекватно заряжать NiMh, пусть даже на минимальном уровне заряда - 100mAh. Или батарейки будут деградировать от недозаряда, и для этих целей лучше подойдет что то типа такого www.aliexpress.com/item/…/32672573427.html?algo_ex… , Opus BT-C3100?
Что-то вроде того. Пользуюсь Maha C9000
