ikarus osd (osd + автопилот + наземеная станция + перекл. камеры +...)
KIR2142
Нашел еще одну довольно интересную OSD, появилась вроде как около месяца назад, стоит 168$, зато сколько в ней интересного:
IKARUS OSD Features: ​
  • 5 Configulble displays: - 3 configurable flight displays (including hud F16)
  • 1 Screen Fail Safe configurable - 1 configurable summary screen (maximum speed, total distance traveled , total time, …)
  • Autopilot, ComingHome and 31 WayPoint - Autopilot: IKARUS control aileron, elevator, rudder and motor
  • Artificial horizon
    - Pan Gain: Multiplication factor for the travel channel PAN. (180º) - PPM Control Input
  • RSSI
  • Telemetry (embedded in the video decoding using USB video capture)
  • USB port for setup and adjustment IKARUS OSD with console
  • Supports many GPS 10Hz (recommended Locosys LS20033)
    - Camera Switch ( 2 video inputs )
  • AUTO PAL / NTSC
  • Auto BaudRate
  • Charset Editor
    - Assistant calibration and configuration: Sensor IR, RSSI, and servo current sensor
  • Until 30 differents flight instruments in every screen: Aircraft speed, Altitude, Compass, Artificial Horizon, variometer, RSSI, number of satellites, Arrow Back home, battery voltage, motor instant consumption, battery level, total flight time, latitude, longitude, distance home, waypoint distance, alarms, odometer, horizontal and vertical antenna orientation. The settings can be: text, bar or F16 Hud
​ SPECIFICATIONS ​
  • Size: 54x32 mm.
  • Weight: 16 gr.
  • Consumption: mAh
  • Power: between 6.5 to 13 Volts
_ Setup IKARUS OSD : ​_
  • Video System: PAL / NTSC (auto)
  • Offset vertical, horizontal and vertical positioning of the telemetry
  • Number of cells in the Video and Motor battery
  • Capacity motor Battery
  • Current sensor and RSSI settings ( help asistententes )
  • Name pilot
  • GPS Speed (auto / manual)
  • OSD Displays
  • Telemetry: embedded in the video, external (MODEM), none
  • Input control, PPM channel and control mode: normal servo input or PPM signal multiplexed
  • Select camera
  • Measurement system: Metric or English
  • Alarms: Low battery voltage, distance, altitude, speed
  • Precision Waypoint
    - End of Route: go to home, repeat route, reverse route, reverse and repeat route.
  • Relative or absolute altitude, latitudes and longitude
  • Firmware upgradeable
​ Autopilot: ​ two ways of connecting
1. Receivers with PPM frame output: to get a stabilization connect a Copilot head CPD4 to IKARUS. In this case, ikarus takes control of the aileron, elevator, motor and rudder
2. Normal receivers (PCM or PPM) without PPM frame: need a stabilization system, a CPD4 Copilot, Copilot II or inertial systmes Type FY20A
CONTROL
You only need a single spare channel to control all Ikarus functions. With just 1 channel you can while flying:
  • Select Screen 1, 2, 3
  • Select CAM1 or CAM2
  • Select GO Home or GO Route(next waypoint)
  • Turn ON/OFF autopilot
Если вкратце:
  • Умеет сама(!!!) стабилизировать самолет при наличии датчика горизонта (головы копилота к примеру), так же к ней можно подключить фишку и горизонт будет выводить на OSD.
  • Имеет встроенные переключатель Камера1 Камера2
  • Может летать по вейпоинтам 31шт
  • Автопилот умеет рулить всем, включая ГАЗ. Причем можно разделять - например автопилот рулит газом и руддером, а фишка элеронами и высотой и т.д.
  • Вывод RSSI имеется также
  • Совместима с РАЗНЫМИ датчиками GPS
  • Не понимаю как, но заявляют что всего одним каналом можно управлять ВСЕМ (режимы OSD, переключать камеры, включать автопилот, переключать режим RTH/Go Route)
  • Из этого вытекает, что модель можно запрограммировать при потере сигнала лететь на определенную точку/точки, а не только домой. Причем у каждой точки можно запрограммировать высоту.
  • Наземная станция (на компе можно видеть доп. информацию)
  • А еще у них заявлено появление в ближайшее время аплинка, где обещают
WITH optional IKARUS UPLINK (still in production)
  • Telemetry uplink using your own R/C transmitter (yes, you can clic over a map and upload waypoint in real time)
  • Joystick control. Compatible with any USB Joystick
Можно задавать и точки в полете и рулить абсолютно любым USB джойстиком!!!
www.electronicarc.com/catalogo/product_info.php?cP…
samabs
Лично мне не нравится когда мой самолёт умней меня! Я между прочим тоже порулить хочу.
baychi
Судя по ролику, они видео через IP передают. 😃
cstrike
baychi:
через xbee
Как это возможно, что один канал может контролировать все :
  • Выберите Экран 1, 2, 3
  • Выберите CAM1 или CAM2
  • Выберите домой или GO Рут (следующего пункта)
  • Включение / выключение автопилот
baychi
KIR2142:
А где, кстати, она растет?
KIR2142
Нет, с видео все нормально там, просто захватывали его прямо на компе, где оно и выводилось, поэтому тормоза. Вот снято камерой со стороны:
продается тут:
А вот его с фишкой стыкуют через разъем для копилота:
AsMan
cstrike:
А как автомагнитолами по двум проводам уравляют? 😃
Vall
Всего то 120.00EUR + GPS 47.00 ЕВРО заманчиво однако.
ИКАРУС OSD + Мастер + Наземная станция +…
[Икарус]
Увеличить
Информация обновляется.
ИКАРУС OSD, более OSD: OSD, автопилот, наземной станции телеметрии, камера Switcher, Servo двойной
Навигационная система ИКАРУС OSD для FPV и БПЛА самолетов, это сейчас одно из самых мощных OSD рынка
Полет консоли:
  • Конфигурация все параметры ИКАРУС OSD (тревоги, маршруты, автопилот, распределение текста, различные экраны и т.д. …)
  • Видео, Карта и инструментов для управления самолета в живом времени.
  • Доля местных позиции сети самолета с другими пользователями ИКАРУС OSD.
  • Также может быть отображена на карте консоли позиции одного или нескольких самолетов одновременно
ИКАРУС OSD характеристики:
  • 5 Configulble отображает: - 3 настраиваемых отображает полета (в том числе HUD F16)
  • 1 экран Fail Safe настраивается - 1 конфигурируемый экран резюме (максимальная скорость, общее расстояние, пройденное, общее время, …)
  • Автопилот, ComingHome и 31 WayPoint - Автопилот: IKARUS управления элеронами, лифт, руль и мотор
  • Искусственный горизонт
    - Пан усиления: Коэффициент пересчета для Travel Channel PAN. (180 º) - PPM вход управления
  • RSSI
  • Телеметрии (встроенные в видео декодирования с использованием USB захвата видео)
  • USB-порт для установки и настройки ИКАРУС OSD с консоли
  • Поддержка многих 10Гц GPS (рекомендуется Locosys LS20033)
    - Камера переключатель ( 2 входа видео )
  • AUTO PAL / NTSC
  • Авто BaudRate
  • Charset Редактор
    - Помощник калибровки и конфигурации: ИК-датчик, RSSI, и сервопривод датчик тока
  • До 30 Дифференц полета инструментов в каждом экране: Самолеты скорость, высота, компас, искусственный горизонт, вариометр, RSSI, количество спутников, Стрелка Вернувшись домой, напряжение батареи, двигатель мгновенно потребления, уровень заряда батареи, общее время полета, широта, долгота, Расстояние дома, точку расстояние, сигнализация, одометр, горизонтальной и вертикальной ориентации антенны. Настройки могут быть: текст, бар или F16 Худ
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
  • Размер: 54x32 мм.
  • Вес: 16 гр.
  • Потребление: мАч
  • Питание: от 6,5 до 13 вольт
Установка ИКАРУС OSD:
  • Видео система: PAL / NTSC (автоматический)
  • Смещение вертикальных, горизонтальных и вертикальных позиционирование телеметрии
  • Количество ячеек в видео и мотор батареи
  • Мощность двигателя батареи
  • Датчик тока и RSSI настройки ( помощь asistententes )
  • Название экспериментальных
  • GPS Speed (авто / ручная)
  • OSD отображает
  • Телеметрии: встроенные в видео, внешние (модем), никто не
  • Входной контроль, PPM канала и режима управления: нормальный вход сервопривода или PPM сигнал мультиплексный
  • Выберите камеру
  • Системы измерения: метрические или английском языке
  • Сигнализация: Низкие напряжение аккумулятора, расстояние, высоту, скорость
  • Точность Точку
    - Конец маршрута: идти к дому, повторить маршрут, обратный маршрут, обратный и повторить маршрут.
  • Относительной или абсолютной высоты, широты и долготы
  • Обновление ПО
Автопилот: два способа подключения
1. Приемники с PPM рамки выход: чтобы получить стабилизации связаться голову CPD4 Copilot на ИКАРУС. В этом случае, Икарус берет на себя управление элеронами, лифт, двигатель и руль
2. Нормальный приемников (PCM или PPM) без рамки ЦБК: необходимость стабилизации системы, CPD4 Copilot, второй пилот II или инерционного типа systmes FY20A
  • Cam быть использованы: на нормальные самолеты (направление / элероны, руль высоты и двигатель), крылья и Vtail самолетов.
  • Управление маршрутов, максимальная 31 путевой точки, маршруты могут быть сохранены и нагрузки в другое время.
  • Если вы потеряете сигнал управления по радио, входит FailSafe и самолет вернулся домой в автоматическом режиме (необходимо предварительно установить отказоустойчивый для этой цели)
Полет консоли. Это будет полет дисплей, который покажет видео из самолета. Телеметрии информации, закодированной в бахромой слева от изображения будут расшифрованы в консоли, обновление на карте положение плоскости, и различные инструменты плоскости.
В окне карты, вы можете видеть положение самолета и ориентации. Длинная линия свяжет с домом плоскости хранятся в консоли, что позволяет легко ориентации для пилота. Другая линия (желтая) ссылка плоскости следующего пункта на маршруте.
Включает в себя: Главная ИКАРУС OSD
ТРЕБУЕТСЯ: GPS и GPS Conextion кабели. (Рекомендуется Locosys LS20033)
ДОПОЛНИТЕЛЬНЫЕ Требуется: ИК Глава Copilot и кабель, видео-захвата, ДТ
AsMan
А икарус то по ходу и не в курсе.
DenisK
cstrike:
Руддером и тумблером . Или несколькими тумблерами замиксоваными на один канал. У них написано в описании.
baychi
Правильно ли я понял, что 168$ стоит только базовая платка, а GPS, датчик тока, пиродатчики или внешний стабилизатор докупаются отдельно?
И что доп. бародатчиков типа скорости, высоты или датчика температуры к ней не подключить?
DenisK
Да, датчики выносные все и за отдельные деньги, и стаб естественно тоже. Но вся прелесть в том, что подцепляется практически всё что хочешь. Думаю и баро не проблема будет со временем.
Я с ними списывался на предмет подключения фишки. Сегодня уже оттестили и подтверждающий ролик выложили оперативно.
Ребята молодцы, китайцев уделали пополной (моё мнение)
KIR2142
На сколько я понял, датчики тока прямо на плате, GPS покупаешь отдельно, причем можно разные, стабилизатор можно не покупать, если есть голова копилота он стабилизирует сам. В принципе даже с учетом этого 168$ + стоимость GPS вполне адекватная и сопоставимая цена, тем более если учесть такие фишки как переключатель камер и т.п.
Vall
контролирует все РPM-модуль адаптирован в девайс управляется по одному дискретному каналу примерно как… “Опустить -Поднять Закрылки” функции последовательно переключаются по кругу.😛
DenisK
KIR2142:
Неправильно поняли
Vall
Утерли нос, всем на удивление Испанцы из IKARUS Sevila
baychi
Vall:
Это чем-же? Прибавьте к 168$ стоимость FMA голов, GPS и датчика тока - сколько выйдет?
И что они такого предлагают, кроме полета по точкам, чего нет в Eagle или у SmallTim?
Vall
Мощное простое и понятное программное обеспечение + Цена
SmallTim? 6000рэ + 7000РЭ уже 315ЮРО
Eagle комплект на 70% 300УС долл.
KIR2142
Ну скажем камера свитчер тоже отдельно стоит 30$, а тут он уже есть. А еще в ET стабилизации нет - тут есть. Ну а полеты по точкам так за них вообще все бешеных денег хотят, так что адекватная цена вполне.
Oliver
KIR2142:
Насколько я понял Тимофея - навигация по точкам намеренно не включена в функционал тим-пилота. Не суть, из каких соображений, но точно не из-за высокой сложности (и, соотв., стоимости) ее реализации.
cstrike
не понял:
  1. как реализован трекер антенны?
  2. в софте можно указать источник телеметрии, там 2 пункта - video, xbee. Xbee может только передавать телеметрию или еще и принимать, или полностью управление можно через него замутить?
  3. правильно я понимаю? видео приемник подключается к тв тюнеру(AV - USB-) ноутбука, ноутбук из видео картинки выдирает телеметрию?
Oliver
Может добавить в табличку по сравнению телеметрий/пилотов? Например очевидно, что бародатчиков нет и некуда подключать, в отличие от. С другой стороны - полет по точкам и два входа камер. Цена, кстати, не больше и не меньше. Вполне себе адекватная цена. Чего заманчивого в ней - непонятно.
cstrike
Oliver:
вы скачайте софт для нее и поймете, что с такими расширенными настройками еще не было ничего подобного
Oliver
cstrike:
Но бародатчиков то нет. 😃
Я не говорю, что в этой новинке ничего интересного. Я говорю, что цена вполне себе рыночная. Не ниже и не выше (девиации в 10% туда-сюда - не в счет).
