Feiyu Tech FY MiNi3D 3 Axis Gimbal
поиском тему не нашел. решил создать. планирую приобрести данный подвес. есть владельцы такового?
Features:
Three working mode: Heading Follow Mode/Heading and Pitch Follow Mode/Heading Lock Mode
Suit for Gopro4 Gopro3+ Gopro3 Sport Camera or cameras with similar size
Magnetic encoder can accurately perceive attitude in motor sports
Leading motor-drive solutions, smooth and stable sine wave output
Single attitude sensor intervention,accurately sense three motor position relationship
Seamless exchange-axis technology
Motor Built-in limit,ensure the orderly rotation to prevent stranded wire
CNC, anodic oxidation frame processing techniques
Gimbal initialization method:
The gimbal is placed,remain stationary,then turn on the power,wait gimal operation,after operating,you can pick up the gimbal to work.
When connect to RC receiver it can switch in 3 working modes, also can control the heading and pitch via the RC receiver.
Heading Follow Mode:
Camera Pitch and Roll angles remain constant, heading follows
the nose position,pitch can be control by RC .
Heading And Pitch Follow Mode:
Camera Roll angle remains constant. Heading follow
the nose position and Pitch follow the elevation of the aircreft.
Heading Lock Mode:
Heading, Pitch and Roll are all locked to point at one position.
Heading and pitch can be control by RC .
The gimbal needs to be initialized when the following situations occur:
-After starting,there is a small angle deviation between pitch angle and the horizontal.
-There is a small angle deviation between roll angle and the horizontal.
-Keeping heading stationary,heading angle has frequent small angle correction.
Products Caution:
1.Please after installing for Gopro camera ,open the power.
2.Be sure to use the USB conversion head when you connect it to the computer for upgrading firmware,
3.First time using,turn on the power of gimbal,remain gimbal stationary,wait that gimbal initialization is completed,automatically back the gimbal to the horizontal position,it can be used normally,you needn’t setting and adjusting parameters.
Note😁on’t use the gimbal over half hour.
Package Included:
1x MiNi 3-axis gimbal
Вот тема
Там про этот подвес.
серьезно? я там вижу совсем другой подвес, ручной…
В этой теме этот подвес тоже умоминиестся и есть по нему отзывы. В последних партиях все косяки поправили.
Но отдельная тема это хорошо
я очень расположем к этому подвесу по двум причинам.
- мини размер
- весь 149 грамм.
цена вроде как не заоблачная. Конечно, хотелось бы услышать\увидеть реальных владельцов. Планирую его ставить на самый первый фантик
Подвес есть у меня понравился. Мелкий и лёгкий.
Работает из каробки. Рассчитан под gopro под камеру хиаоми нужна другая рамка есть в продаже.
о! инфа по рамке полезная!
Рамку брал на бангуде. Прежняя закреплена ооочель хорошо на фиксатор резьбы. Еле открутил.
я решил спросить у продавца ( на Ибее). может он сразу отправит с рамкой для Сяоми. Подождем что скажет.
На бангуде поставил крест. Купил там один раз. Мало того что оооочень долгая доставка. Так еще и брак приехал. Теперь только Али , а еще лучше Ибей.
Никита, у тебя на чем стоит подвес?
купил для теста.
на коптер не ставил.
Не понял только в каком месте он мини. Такой же громозкий. Ну может за счет пластика не такой тяжелый. Если ставить подвес на самолет то нужно как можно меньше мидель делать.
Камера + мотор питча это уже широко а здесь сбоку мотора еще плата контроллера питча с кожухом приделана… На коптер наверное нормально. Если быстро не летать.
Тоже сегодня стал обладателем сего девайса.
Да, работает из коробки. Воткнул ГоПро1 Подошла, но впритык, по центровке - не очень. Включил - все работает. Походил по квартире… Мне понравилось. Стабилизирует хорошо, третья ось хорошо работает. Понравилось 😃
ПО настройками не блещет 😦 Пару гейнов и усе…
Буду ставить на коптер, посмотрим как оно в воздухе будет работать 😃
отпишись поскорее! ))
тоже такой хочу.
У меня тоже такой подвес, но вот ,что то не могу вывести видео с gopro 3+be, не идет. Подскажите в каком режиме должна быть gopro ?
Сам подвес работает, брал в августе с алиэкспреса и оформлял с мобильного приложения - попал на очень-очень хорошие скидки .
Ну чтож, собрал коптер с данным подвесом. Полетал. Поставил, пока, что есть Гопро-1. Она не очень подходит по балансировке. Но, тем не менее, подвес прекрасно справляется со своей задачей! 😃
При полетах вперд-назад тряски не наблюдаю, стабилизирует очень хорошо. При очень резких маневрах (например, как при настройках ПИД) есть не большие запаздывания в реакции. Думаю, это можно подправить Гейнами в скромном софте. Хотя, в нормальном полете таких “маневров” не должно быть.
В целом, я доволен.
я этой фирмы взял ручной стабилизатор - бомба! вот теперь еще больше склоняюсь к этому!
Тоже являюсь обладателем данного подвеса. Очень он меня порадовал, все грамотно продуманно. Цена и вес очень радует! Да и качество стабилизации не плохое, при том, что он работает из коробки.
Тестили в прошлом году этот подвес.
GOPR1146
вот видео этого подвеса,
yadi.sk/i/YB7weBsxk3n6W
есть мелкое дрожание, но думаю надо лучше пропы балансировать и баченки 4 из 6-ти поменять на более жесткие или хотя бы 2, воообщем пока в поиске…
Тоже приобрел, работал безо всяких дрожаний, пока работал. Но после 2х посадок перестал совсем двигаться. Сдох.
Слишком нежный для самика. Причем, старый подвес работает без проблем, тяжелый такой - G3 ULTRA 3-Axis, и хотелось полегче.
Теперь не знаю, заменят или нет. Нужно чем-то страховать его при посадках. Пока думаю просто отключать (дистанционно с АППЫ) питание при посадке, перед касанием. Меньше нагрузка на потроха.
Может че ещё?
Я в 14 посте писал - что у меня нет видео с гопро с этим подвесом. Так вот спасибо Алексею (swat0russia ) - опытным путем установили, что виновник всему черненький проводок ( а скорее его распайка ). Причем разобрав разъем и попытка перепоять, даже с добавкой резистора( как в интернете делают самодельный провод )не заработало. С офф сайта был заказан этот проводок - сам провод 4$(250 рублей ) а вот доставка - 530 рублей. Пришел в коробке 20 см Х 20 см и толщиной 6 см да еще внутри сам упакован в несколько слоев пупырчатой пленки ( видно доставку отработали по полной ). Итог все работает !
сртанно, у меня все из коробки пошло…
Всем привет! А интересно ПРО версию этого подвеса, уже кто нибудь опробовал в действии?
Тоже самое, только по ЯВ на 360 вращается.
Мне вот интересно каким образом подвес настраивается под GoPro 3 и 4, ведь у них совершенно разная развесовка, и тот же Зенмус H3-3D корректно с Четверкой не работает, и наоборот H4 срывает когда на него вешаешь Трешку. Как во Feiyu реализована совместимость с двумя типами Прошек?
