Rabbit Flight Controller
Ещё один новый контроллер от китайцев.
Description:
- This Flight controller adopts 32 Digits ARM CPU and latest sensor with Independent research and development software, ensuring stable and reliable flight in a simple setting suface.
- The board contains high precision tri-axis gyroscope and tri-axis accelerometer with compact structure and size.
- With stable and balance function without any aditional board.
- Multi-function: can be connect with ultrasonic, pressure meter,tri-axis magnetic sensor,GPS,thus to reliaze Fixed Hight,Fixed Direction, and self- lift-and- down function.
- 8 Channel remote input and 8 Channel motor/servo output.
- Support aerial photography and PTZ Self-Balance.Output mode can be set by user.
- With USB interface, Upgrades PC and adjusts parameters without Expansion Board.
- Provides PC upgrade tools and improve program accoding majority users requiments .
Features: - With care free function
- 32 digits 50 MHZ CPU
- Support 140g mini quardcopter.
- with high precision tri-axis gyroscope and tri-axis accelerometer with compact structure and size
- 8 CH recieve channel, can set Auxiliary switch channels and PTZ control channel except 4 Rocker channel.
- 8 channel 16 digits output channel,can set 50Hz~500Hz analog/didital servo or non- standard ESC singal.
- Supports mix-control: GIMBAL,BI,TRI,QUADP,QUADX,Y4,Y6,HEX6,HEX6X,OCTOX8,OCTOFLATP,OCTOFLATX,FLYING_WING,FIEXD WIND mode and so on. can be add other mode according users requirement.
- Provides PC upgrade tools and improve program , convienent for users to set parameter,and download the newest program.
- Supports quad-axis, hex-axis,eight-axis quadcopter( can not connect to PTZ as all the pins used to connect motor)
- 8 LED singal to indicate various mode, convinent to set parameters anytime even for a tiny adjustment. Can connect color LED strip, makes magnificant and unique night flight.
- supports 4S battery Voltage test, avoid overdischage.
- provide alarm port,facilitate users to set low power alarm, the arning tone will be pressing as the power lower and lower.
- with ultrasonic port, makes fixed hight function range 2 meters, perfect performance especially for the ground grading.
- with equipment selfcheck function, make sure safty flight . with sound and light signal in the selfcheck procedures.
- with high precision tri-axis gyroscope and tri-axis accelerometer,facilitate users to add functions such as Automatic landing and Fixed-point return.(just buy additional board and download online upgrade software is ok)
- with Independent research and development software, can improve or add new functions as user’s requirements.
- Optinal output mode: Default ESC output 330MHZ.47HZ servo output, Servo/ESC output option:50Hz(20ms);100Hz(10ms);270Hz(3.6ms);330Hz(3ms);500Hz(2ms Special ESC);2KHz PWM(Special ESC)
Specifications: - Alarm Voltage setting:3.4V~3.7V
- Gyroscope: ±2000dps,16 digits resolution ratio, responding time:1000HZ
- Accelerometer: -8G,14 digits resolution ratio, responding time:800Hz
- Input Voltage:4~6V (provides by ESC)
- Board Szize:5.5mmX5.5mm
- Weight:20g
- Working Temperature:-40~+85
интересно: какого лешего они светодиодов насували ?
ведь по хорошему мозги прячутся… смушает адекватность разработчика…
световая индикация настроек. но мне тоже кажется что 8 - много.
Нате лучше мануал покурите чем гадать;) www.rcgroups.com/forums/showatt.php?attachmentid=4…
Появились некие видео (где фиг чего можно понять)
v.youku.com/v_show/id_XMzM2MTE4MTQ0.html
www.tudou.com/programs/view/p6b_XV60BW0/
настройка на компе
Еще интересное фото
bbs.5imx.com/bbs/attachment.php?aid=865129&noupdat…
Увы, это мануал не от этой платы, а от этого проекта
кстати, 2 варианта платки есть.
в подороже которая написано “With care free function” - что бы это могло значить?
Функция свободного ухода? Что это?
В более дорогой - просто отдельно припаян магнетометр и барометр
Care Free режим, это когда пофиг какой стороной к вам летит ЛА, стик от себя - коптер летит от пилота, на себя - к пилоту и тп
Не совсем так… Вернее так, но только если пилот не отходил от того места, где происходила инициализация мозгов.
Ибо коптер не знает, где сейчас пилот, а вот именно место своей инициализации как раз запоминает.
И летит к нему или от него, а также вправо или влево относительно него - в зависимости от движения того стика, который Рол-Питч (у нас обычно это правый)
Эта фича есть у немцев в МК, есть в МегаПирате (следовательно, должна быть и в АрдуПилоте) - наверняка еще в нескольких контроллерах, но не во всех.
Мне кажется удобной для новичков пилотирования вроде меня самого. Только понимаю, что если на эту фичу “подсесть” - то так и не научишься управлять коптером по-настоящему.
… когда пофиг какой стороной к вам летит ЛА, стик от себя - коптер летит от пилота, на себя - к пилоту и тп
ВАУ здорово вот бы для верта такую примочку, а то нет-нет да зарулишся в матушку землю 😃
Эта фича есть у немцев в МК, есть в МегаПирате (следовательно, должна быть и в АрдуПилоте) - наверняка еще в нескольких контроллерах, но не во всех. Мне кажется удобной для новичков пилотирования вроде меня самого. Только понимаю, что если на эту фичу “подсесть” - то так и не научишься управлять коптером по-настоящему.
- я тож самоe добавил в мультиви… уже есть в дев прошивке на офф сайте…
чеб не привыкать к нему использую только когда зарулился 😃
Взял себе на попробовать одну штуку- ту которая с баро и компасом. Вчера оплатил сегодня повезли на почту, что-то быстро для GBL.
Буду разбираться с китайским, на китайском форуме пока хвалят этого кролика,но отзывов пока маловато.
Goodluckbay ответил - “Ждите дополнительную информацию позже…”
Ну и заказал для кролика - Ultrasonic Module HC-SR04, для полноты комплекта 😃.
Инструкция для “кролика” (Rabbit Flight Controller) на английском - www.megaupload.com/?d=NIKULASX
Видео как работает Care Free на Rabbit Flight Controller:
ссилочку не подкините на етот ультрасоник?у меня тоже кролик уже заказан…
Подкину 😉.
Взял тут: www.ebay.com/itm/280778106586
english manual + software chinese version with Text explanation - сообщение №8 на форуме:
www.rcgroups.com/forums/showthread.php?t=1564594
Теперь доступно - Rabbit-PC-Tool (английская версия) - www.goodluckbuy.com/images/…/Rabbit-Pc-Tool.rar
Интересно если контроллер поставить на самолёт и выбрать в программе "13–FLYING_WING или 14–FIXED_WING " как будет работать удержание курса и высоты в нем. (Direction lock,Height lock ).
интересно спросить, получил ли кто кролика поюзать?
У меня пока - 3.01.2012 Вылетело из Гонконга в страну назначения 😦.
translate.google.lv/translate?sl=zh-CN&tl=ru&js=n&…
страничка с причиндалами
Какое приимущество дает плата за 89$ по сравнению с платой за 59$ ?
в дорогом +барометр +3х осевой компас - должен уметь зависать в точке
немного не отсюда но всеже, хотел брать плату датчиков (все в одном) но самый дешевый вариант около 90$ с доставкой а тут все теже датчики + атмега и всего около 70$ aliexpress.com/…/515715055-Hot-free-shipping-MWC-v…
ОО,давайте заказжем 6 штук за 65$ =)
Мне 1 нужен.
А софт то где под него есть?
