NAZA-M LITE
Народ, не знаю, сюда надо или в тему про таранис, но ситуация следующая.
Купил себе аппу, наза у меня была, прошивалась и летала, все было нормально. Но когда я заменил turnigy 9x на таранис, у меня вылетает куча ошибок, в наза ассистенте.
Смысл их понимаю примерно, но куда копать - не пойму.
Цитирую:
Motors Start failure caused by TX stick(s) mid point error too big
If the TX stick(s) mid point error is too big, Motors Start will fail when you execute the Combination Stick Commands (CSC) and lead to the aircraft will not takeoff… And the LED will blink Red four times per second continually to warn you.
TX stick(s) mid point error too big can be caused by the following reasons:
(1) There is TX stick (except the throttle stick) not at center when power on the autopilot system.
(2) The TX sticks has been trimmed, which leads to the large deviation of mid point. For example, the SUB-TRIM has been adjusted for Futaba transmitter.
(3) The TX stick(s) travel has larger asymmetry.
For the reason (1), please put all TX sticks at the mid point, and then power cycle the autopilot system to re-record the mid point. If the problem continues, that can be caused by the reason (2) or reason (3), you need to adjust the output range of your TX, and then use the Assistant Software to redo the TX calibration. Please carry out the following procedures.
(1) Connect to the Assistant software, click Basic-> R/C-> Command Sticks Calibration, and push all TX sticks throughout their complete travel range to see if any stick cannot reach its largest position.
(2) Adjust the largest travel of TX stick until the cursor on the Assistant software can reach both end positions, according to your TX manual.
(3) Power cycle the autopilot system, note that power cycle is required.
(4) Redo the TX calibration according to the Assistant software.
И еще: Полетные режимы смиксировал, IOC тоже, калибровку стиков сделал. Они стоят по центру, все нормально. Единственное, это элероны отклоняются вправо на 75%, а не на сто…
Куда копать, и где уменьшать эту центральную точку?
В тему про таранис естественно, у Вас ни одной ошибки связанной с назой… Все проблемы исключительно с ТХ. Начните с изучения мануала на таранис, рано или поздно это придется сделать, как бы в падлу не было…)
мне не в падлу, изучаю потихоньку, но очень много непонятного все-равно))))
Цитирую:
переводчик обработал.смысл более менее тоже.ругается как написали на аппу.
translate.google.ru
Всем доброе время суток!
Получил кронштейн на сервах (без электроники), у меня вопрос подключаю к назе и все? Ну с настройками покопаюсь.
Или еще что то нужно.
Кронштейн простенький, такой ru.aliexpress.com/item/…/1804798567.html
Покупал до кучи вместе с мелочевкой.
Да… Больше ничего не нужно…
Заметил,что полётное время сильно уменьшилось.
Та же история, квад около 2 кг, стоял MultiWii, летал больше 25 минут. Заменил на Naza-m v2, время полета стало около 12 минут.
Второй квад, вес около 1.3 кг, с кроликом летал 15 минут на батарее 2.2A, после замены на Naza-M Lite время полета стало около 7 минут.
В обоих случаях контроль по напряжению отключен?
Да, на обоих квадах стоят пищалки.
Есть такая штука… закон сохранения энергии… А теперь вопрос, куда подевалось 50% энергии аккумулятора? Либо летали в несколько раз быстрее, либо нечто подобное.
Имхо, контроллер столько не кушает. 10-20% еще бы можно было списать на кривые настройки и т.п., а уж 50% - такого не может быть.
И прям батареи всухую? какая батарея и сколько зарядник в неё залил после полёта?
На том кваде что по массивней две батареи 4S 3300 в параллель, после 12-13 минут висения на месте зарядник заливает по 3100-3200
Я в курсе но факт есть факт
квад около 2 кг
Скушал 470 Ватт? Это эффективность 4.25 грамма на ватт, такого не может быть…
но от действительности не уйти
- к сожалению!.. Но Наза тут не при чём!Поставил КК2.1 - картина прежняя.Аналогичный сетап,догруженный до веса нынешнего,кушает ок.13А,а этот -18-19.
Грешил на Afro Slim 20A,поменял на одном луче на регуль другой марки - без изменений.Попробую исключить силовые коннекторы Ф2мм на регулях - на "правильном"сетапе всё на пайках.Повторюсь - Наза не причём,и дискуссию надо переносить в другую тему.
Подскажите на что нынче стоит/целесообразно/наиболее удачно шить Назу Лайт?
Скажите какие у вас есть варианты?
Ну я обновлялся полгода назад на 4.02, думаю может с тех пор что-то поменялось, а поскольку перехожу с квадро на гексу, то вот и уточняю, что бы если чего, то сразу и обновиться на то что посоветуют.
всем привет
купил назу лайт. настроил ее под win 7,
при включении квадрика наза начинает быстро мигать желтым огнем и не стартует движки
если движки включить и двигать стик газа то светодиод периодически моргает зеленым
приемник flysky FlySky FS-R9B
наза подключена на 1-4, 6,7,8 каналы
собственно делал все как в этом видео
вопрос второй: как заставить dji assistant видеть назу под win 10/8,1? читал англоязычные форумы-но какого то единого решения не нашел
Нормально она видится под 8.1 и под 10… После обновления драйвер надо переустановить.
не хочет, в дистпечере устройств есть, ассистант ругается что “no mc connected”
Тоже подтверждаю -нормально всё. Драйвер не переставлял.
У Вас режим Fail-Safe. Асистант надо новый скачать (на видео старая версия). В нижнем левом углу у Вас написан режим.
это видео на ютубе нашел
скачивал ассистент последний с сайта dji
Режим у Вас Fail-Safe. Поэтому частые желтые моргания.
В Win7 в асистанте режим посмотрите.
