DJI Phantom 4
всем такое пришло?
DJI will soon introduce a new application activation process for international customers. This new step, to take effect at the end of this week, ensures you will use the correct set of geospatial information and flight functions for your aircraft, as determined by your geographical location and user profile. All existing flight safety limitations, such as geofencing boundaries and altitude limits, remain the same.
Even if you have registered when activating your aircraft upon purchase, you will have to log in once when you update the new version of DJI GO or GO 4 App. If you have forgotten your password since your initial login, you can reset it using a function within the DJI GO and DJI GO 4 apps.
You will need a data connection to the Internet for your smartphone or tablet when you log in, in order to verify the account information and activate the updated software or firmware. If this activation process is not performed, the aircraft will not have access to the correct geospatial information and flight functions for that region, and its operations will be restricted if you update the upcoming firmware: Live camera streaming will be disabled, and flight will be limited to a 50-meter (164-foot) radius up to 30 meters (98 feet) high.
The feature applies to all aircraft (except standalone A3 and N3) that have been upgraded to the latest firmware or when using future versions of the DJI GO and GO 4 apps.
Перекличку устроим?
Перекличку устроим?
что то напрягает в моем сообщении???
мой пост для тех кто не “подписан” на рассылку от джидаев.
добавь меня в игнор и не будешь видеть моих постов!
Без обид, не принимай близко к сердцу! 😃
Ничего не напрягает, просто этот вопрос уже два дня обсуждается в теме DJI GO, GO 4, GS, Litchi, Airnest, Autopilot и тд - программы для квадрокоптеров DJI.
Мужики посоветуете у меня фант4 прошивка 01.02.0503 а пульт 1.6.0 я так понимаю мне нужно коптер прошить. Можно по wifi? И как не прошить пульт при этом? Go предлагает прошивку…
GO много чего предлагает. 😃 Прошивайте коптер через DJI Assistant 2 подключив его к компу по USB, пульт кстати если случайно прошьёте, то же ничего страшного, легко откатывается назад.
То есть шью через асист а пульт можно не включать ? А аккумулятор автоматом прошьёт ?
Пульт не можно, а нужно НЕ включать, аккум прошьётся автоматом, если их несколько, то надо будет повторить процесс прошивки с каждым подряд.
Спасибо все понял!
Народ, было у кого: ни с того ни с сего потух экран DJI Go, оживил планшет - надпись “связь с дроном потеряна” или “disconnected”, не помню точно.
Хорошо, что дрон я уже посадил. Прям не знаю, что и думать теперь!
Что значит потух экран DJI Go, вылетела программа или вообще планшет вырубился?
Планшет работал, но экран потух, как будто в спящий режим перешёл.
Но так же не должно быть при активной программе?
Только после того, как выключил и включил дрон и перезапустил DJI Go связь восстановилась. Походу что-то подобное у кого-то уже было…
Так причём тогда здесь вообще дрон, если экран потух и в спящий режим перешёл, то ищите проблему в своём планшете, может там какая нибудь функция энергосбережения экран гасит.
Последняя версия джиго 4 довольно ресурсоемкая и ее поддерживают далеко не все планшеты. Попробовал - за полет вылетела пару раз. Я вернулся на 4.0.5. (Редми 3). Там пока все стабильно.
Планшет работал, но экран потух, как будто в спящий режим перешёл. Но так же не должно быть при активной программе?
Тоже было такое - помогла перезагрузка пульта. Планшет Huawei Mediapad M2
Где бы скачать apk этой версии? Не могу найти, везде какие-то глюки.
Добрый день))) Купил неделю назад этого зверька с москвы с доставкой до Уфы…Комплект шикарный два пульта один усилинный с антеннами FPVLR и отдельными усилителями,3 акб. три линзы polaroid nd… Это я похвастался.А вообще когда совершил первый полет моей радости не было придела летает как по рельсам.что не скажешь о моих самосборах раньше.этого зверя даже не страшно отпускать дальше километра от себя… а теперь парочку вопросов.Пока пользуюсь своим телефоном Huawei Honor 5x/ (планирую взять планшет). На родном пульте все отлично картинка не сыпиться и без фризов. Как только подключаюсь через усиленный пульт все … картинку невозможно смотреть зависания,квадратики,розовые и зеленые полосы ну и всякое такое. Подскажите вчем может быть причина. (это был первый вопрос) Второй вопрос возможно ли такой в программе dji Go выставить такой режим чтоб коптер снимал видео но при этом через определенный промежуток времени делал фото …например каждые 5 сек. и третий вопрос может у кого нибудь есть ссылочка или список ошибок с переводом на русский язык которые могут возникать…То есть чтоб не получилась так пришел летать а тут выскочила ошибка и стоишь чешишь репу и думаешь стоит ли взлетать или нет.
По последнему вопросу - скачайте русскую версию dji go, здесь на форуме в соответствующей ветке есть ссылка.
а глюков из за русской версии не будут?
Да не должно быть. Приятель на мавике гоняет без замечаний. Сам использую английскую версию.
Ни вручную, ни в автомате так нельзя. Только останавливать видео и снимать…
По первому вопросу - на разных планшетах прога идёт по-разному. Тут надо ориентироваться на отзывы людей, кто на чём запускает. Например, у меня на планшете видео отличное, плавное, а на телефоне - картинка тормозит и рассыпается. Если каждый отпишется по своим моделям телефонов, вам будет проще выбрать подходящий.
Про себя могу сказать, что на планшете HUAWEI MediaPad T1 10.0 LTE с видео проблем не наблюдаю.
Киньте ссылку - как откатить прошивку пульта ?!
