Hubsan X4 FPV H501S / Pro
Tileva
Garri50:
А в чем отличие 38 от 41 версии?
H501A-FC-V1.1.41
H501A-RX-V1.1.43
  1.   Add the feature for TX only to set the orbiting point when the orbit mode feature is engaged. In normal orbit mode the drones point of focus is on transmitter by long pressing the “video” button on the standard transmitter or “down arrow” button on the advanced transmitter. With this new feature, you can change the orbiting location and diameter.
To do this first hover the drone in desired location (new focus point), long press the “up” button on the advanced transmitter or “photo” button on the standard transmitter. The distance value displayed on the transmitter will change from green to red, the distance value will reset to “0”. The drones position is now the orbiting focus point. Use the elevator stick “up or down only” to set the orbit diameter. Don’t move the elevator stick left and right or it will exit the orbiting mode feature. After distance is set, long press the “down” button on the advanced transmitter or “video” button on standard transmitter to engage your custom orbit location and diameter. While in this orbit mode you can adjust wider or smaller diameters and change your altitude during flight.
When you finish and exit orbit mode the distance value will reset to the correct distance value between controller and drone.
  1.   Add the feature to allow you to adjust the diameter and altitude while the orbit mode feature is engaged using the app by moving the elevator stick up or down and the throttle stick up and down.
  2. Add the feature when the drone is not on a flat surface, tilted 20 degrees or above, the motors will not start.
  3. Improved the follow me issues "exiting immediately when you engage it”
  4. Stability
  5. Improved connection problem when connected to the App and transmitter at the same time.
  6. Improved the distance value display issues where the value would jump when connected to the transmitter.
  7. Improved 2.4 GHz range when connected to the transmitter.
  8. Improved Camera quality if installed with camera firmware version H501A_IT_V1.1.10
  1. Инструкция полета “по орбите” с произвольным центром.
  2. Добавлена функция, позволяющая регулировать диаметр и высоту, когда функция режима орбиты задействована с помощью приложения, перемещая лифтовый стик вверх или вниз, и газ - вверх и вниз.
  3. Добавлена функция, когда беспилотник не находится на плоской поверхности, наклоненной на 20 градусов или выше, двигатели не запускаются.
  4. Усовершенствовали “Следуй за мной”: «выход сразу же, если трогаете управление».
  5. Стабильность.
  6. Улучшена проблема подключения при подключении к приложению и передатчику одновременно.
  7. Улучшены проблемы с отображением значения расстояния, при которых значение скачкообразно сканировалось при подключении к передатчику.
  8. Улучшен диапазон 2,4 ГГц при подключении к передатчику.
  9. Улучшено качество камеры, если установлено с версией прошивки камеры H501A_IT_V1.1.10
Fartowii
Tileva:
H501A-FC-V1.1.41
H501A-RX-V1.1.43
так это прошивки и к 501А подходят? Или я чего то недопонимаю в прошивках и пока не стоит заморачиваться, а то можно и кирпичик на выходе получить)))
NumLock
Fartowii:
Да, прошивка FC подходит.
Fartowii
А есть какие нибудь прошивки для ретранслятора HT005? Просто стоит ли заморачиваться что то искать? А то не конектится что то он у меня с самсунгом да и с яблоком не хочет((
Fartowii
При чём есть два ретранслятора и не один не конектится не с яблоком не с друидом(((
Yurasimo
Tileva:
H501A-FC-V1.1.41
H501A-RX-V1.1.43
H501A_IT_V1.1.10
[/LEFT]
[/LEFT]
абалдеть…
это-то как раз и не хватало
почему про эту фишку нигде не пишут?
Tileva
Yurasimo:
Обсуждалось уже десятки раз. Пишут… читателей нет.)
denis_bingo
Привет народ владею 501ым опыта набрался,но тут завел старшего брата(заранее извиняюсь но по нему вялая тема,неразвита как тут поэтому решил здесь спросить) вот видео yadi.sk/i/8RoaYTANqEP6Ow
Кто что думает?откалибровал взлетел высоту держал,полетел вперёд и когда налево пошел в разворот все началось,стал не управляем кое-как без краша посадил,ну как посадил руками поймал,теперь сижу гадаю что это могло быть,думаю либо мотор,но они визуально не люфтят и не клинят,или полетный.вы что думаете помогите если кто с этим сталкивался и впоследствии решил проблему или просто советом помогите я знаю тут есть специалисты,заранее спасибо
Рамзес888
Для начала сделать ВСЕ калибровки - горизонт, вращение, компас и пульт, и протестить заново.
Replika2
Про аккум в пульт. Хочу поделиться личным опытом. Летаю и езжу как 10 лет. Пульт спектрум траксас и вот…хабсан. Ставил и батарейки и ни-ка аккумуляторы и ли-по. Надежнее всего мне кажутся именно батарейки. Те что щелочные. Они либо работают. Либо нет. С аккумуляторами бывали залёты. Дома проверю…заряд 90%. В работе просадка а то и вообще пульт отключится. Плюс нежные. Следить. Заряжать. Хранить. А 12 батареек стоит 54 р. На жрущем батарейки хубсане улетаться хватает. Все ИМХО ))))).
Garri50
Привет Всем! Вопрос такой, почему такие расхождения в показаниях GPS спутников в показаниях квадрика 8, а пульт 3? Что это неисправность GPS пульта? Посмотрел это на балконе 9 этажа или выйти на открытое место по пробовать?
Рамзес888
Garri50:
Нет! Это неудачная компоновка самого модуля внутри корпуса пульта. У меня пульт Pro - тоже мало ловил спутников - я переместил сам модуль в верхнюю часть и стало ловить практически всегда 11 спутников (приклеил на двусторонний скотч в несколько слоев к верхней части корпуса за боковые части самого модуля):
Garri50
Да я модернизирую пульт со временем, пульт стандартный не про, приобрел несколько дней назад, еще даже не взлетал. Срок проверки 7 дней, погода не летная вот я пока и проверяю что да как! Попробую выйти на улицу на открытое пространство - может там поймает по больше, жалко обратно отправлять и время теплое пролетит!
shurik_1465
Garri50:
Вы бы еще дома проверяли спутники ловить. 😉 У меня на балконе ловит не больше 3, а у Вас 8. На улице пробуйте.
Replika2:
У меня противоположное мнение, тоже летаю 7 лет, по началу в Walkera Devo10 стояли батарейки 8шт, задалбывался менять, купил аккум и вот уже 7-й сезон летаю не менял еще(на зиму на хранение разряжаю -55%)/ На Хабсанчике тоже стоит аккум 3-й год(ПРО пульт). Очень удобно! А то что у Вас были залеты, или индикатор гавно или сами увлеклись и прогавили разряд, не разряжайте до последнего и не будет проблем. Конечно дело каждого что выбрать, но мне на много удобней аккумы. Да, конечно зимой у Липо заряд держит меньше, но и летаем меньше, сопли то морозить не охота.
Рамзес888
Garri50:
Это правильно, здания и строения всегда мешают нормально ловить сигналы не только для GPS.
Рамзес888
Рамзес888:
Как делается калибровка компаса описывать не буду, остальные должны быть так:
При первых двух коптер должен стоять НА РОВНОЙ на сколько возможно горизонтальной поверхности!
denis_bingo
Рамзес888:
Спасибо будем пробовать
denis_bingo
Рамзес888:
Вот такая ситуация при включении обоих коптеров тот что с шторкой 501 к нему нет притензий(это так как пример)и его старший без шторки
yadi.sk/i/Yex7MnW1FX3Few
yadi.sk/i/EtfA0s94K9gXrA
Рамзес888
denis_bingo:
ЯВНО что-то не здоровое, возможно был ударен САМ компас и из-за этого так скачут показания или он или что-то рядом возле него СИЛЬНО намагничено! Размагнитить - способы уже описывались, и в инете много описаний как это сделать!
В Вашем случае (H109S) компас находится в ноге:
Рамзес888
Задумался я о GPS-трекере. В связи с этим ВОПРОС: хочу взять ЭТОТ, как узнать ЗАПРЕЩЕН ли он в России? Не возьмут ли меня СПЕЦ-работники на почте? 😁
Седой75
Рамзес888:
10 положительных отзывов от российских покупателей говорят о том, что их пронесло))
Fartowii
Я тоже заказал. Не должны. А вообще можно сказать что собачку свою буду отслеживать или кошечку. Или попугаю на шею прицеплю а то улетает все время������������
shurik_1465
Рамзес888:
Если в нем нет микрофона, то он не должен относится к спец средствам(прослушка и т.д.). И доказать органам, что это спец.средство тяжело будет. Взял для собачки…
