Новая HD камера ExplorerHD от BevRC
huntsman60
На сайте BevRC недавно появилась новая HD камера, которая называется ExplorerHD. Обещают много чего интересного, в частности высокое качество, полную совместимость с UHF LRS и возможность использования в виде курсовой камеры. Никто еще не успел опробовать?
Вот описание с сайта:
Features:
1: Specially designed for FPV from the start, no ugly cables and bare pcb board outside which cause interfierence, fully sheild in a ALU mental case, no affect with your devices in your plane, UHF friendly.
2: Small size, light weight(58g only), the pan-tilt is designed for it from the start, easy to set up in your plane. Super crash resistant, easy to change the lens.
3: 7-16v wide range voltage input, no need to worry about if you have charged the built-in lipo.
4: 146 degrees wide view angle with clear PAL/NTSC analog video output, according to our test, the AV out quality is more or less the same or better than most of cameras sold in the market, even better than some low-quality 700TVL cameras.
5: Radio-controlled HD record, you can use one channel of your radio to control the HD to record as your wish during your flight.
6: Real HD, same solution as gopro,
16:9 1920×1080(30fps)
4:3 1440×1080(30fps)
16:9 1280×720 (60fps)
16:9 1280×720 (30fps)
So 1 ExplorerHD = 1 min HD camera + 1 high quality FPV camera, easy use as the normal mini analog camera, but also can record real HD video at the same time. What’s more, it’s affordable.
7: Firmware update easily.
Spec:
Image sensor: 1/2.5 CMOS
Effective pixel: 5.0 mega pixels
Lens: fixed focus f3.15 view angle: 146 degrees
Record:
picture: JPEG, 2592*1944
video: 16:9 1920×1080(30fps)
Recording medium: high-speed Micro SD card(TF card), Max 32G support
Dimention: Approx 37*37*31mm
Weight: Approx 58g(not including the memory card and battery)
Youe purchase includes:
1* Main unit
1* power cord
1* Multifunctional cable(plug and play with 5.8G video Tx and one channel of your radio rx)
1* AV connection cable
1* USB data cable
1* User manual
NinjaFoX
Обычная камера, с присобаченным ДВР, скорее всего сони. Имхо пиксим + брелок будет лучше.
huntsman60
Пиксим не умеет писать на флешку в 1080p качестве 😁
huntsman60
Покажите мне брелок, который пишет достойное 1080p 😉
NinjaFoX
Обычный 16-й брелок за 43 бакса. Я не думаю что эта камера будет писать лучше. Там хоть и 720, но качество измеряется не только в пикселях, вот например хоббикинговская камера, которая пишет 1080 - редкое Г.)))
Ну а вообще по хорошему, пока не появится видео с этой камеры, ажиотажа не будет)
huntsman60
А можете дать ссылочку на брелок, про который вы говорите и примеры записи. Можно в приват.
baychi
146 градусов FOV - ни то, ни се, ИМХО.
В остальном - надо смотреть записи. И как курсовая, и как HD писалка может оказаться - вполне себе, а может и отстой полный.
Если кто будет первопреобретателем, милости просим отчетикс… 😃
nedz
baychi:
вчера заказал, посмотрим…
SlonSpb
nedz:
О… первопроходец ! Ждем отчета.
nedz
будет отчет! искал легкую камеру для съемки с бикслера или х5, гопрошка стоит на х8, на маленькое крыло ее проблематично ставить. а тут и курсовая, и на флешку пишет. Конечно не HD, но … попробуем!
SkyWorker
nedz:
Почему же не HD?
nedz
на ХК уже продают HD banned link
качество ужасное…
SkyWorker
nedz:
качество ужасное…
Но там и цена 1300 рублёв.
А эта 130 баксов. Все же думаю разница будет.
SkyWorker
nedz:
Андрей, на это и надеюсь!
Надейтесь! 😃 А мы на халяву посмотрим… 😃
Dacor
Да… Цена, конечно, завлекает. Но и отпугивает одновременно… Да и форм фактор то что доктор прописал. Нужно смотреть ролики и сравнивать (хотя бы по сравнению с брелками).
huntsman60
Камера на самом деле уникальная. Курсовая и записывающая в 1-м небольшом корпусе. Может быть даже в стандартное поворотное устройство влезет? И что самое приятное, в отличие от многих, в том числе и GoPro 1-й, судя по описанию никак не влияет на UHF LRS. Если еще и качество хорошее, то цены ей не будет. Так что ждем обзорчитка 😉
SkyWorker
huntsman60:
В чем уникальность? Гопро делает тоже самое. Только наверняка лучше и при этом еще ударопрочная.
huntsman60
Камеру еще опробовать не успели, а уже набросились с критикой… Давайте хотя бы обзора от владельцев дождемся. Ведь все мы ждем более дешёвой альтернативы GoPro 😒
С GoPro сравнивать не совсем уместно, ибо она стоит в 2 раза дороже. Но все равно, форм-фактор тут гораздо интереснее. Проще устанавливать, особенно на поворотку. И сквозное видео с нее гораздо проще выводить, как мне кажется. Но самый главный плюс я уже 3 раза назвал, это совместимость с UHF. Если конечно в описание не обманывают 😎
T300
huntsman60:
Любую камеру засунь в металлический корпус, и после, смело пиши о совместимости с любой LRS, в том числе, и UHF. 😃
Dacor
Значит скоро пойдут и отзывы!
P.S. Че то какое то фото не очень…
nedz
Dacor:
думаю дней через 10, мне придет…
